I would like to create my own custom plugin panel that will extend basic Time-series or Bar graph panels. Simply what I need to do is to show for example Time-series panel and next to it have some buttons or other react code. Is it possible?
I am familiar with plugin development in Grafana but never have I seen custom plugins using built-in panels.
@adamhowaniec You can’t have nested plugins, unless you are using Scenes.
You can create a new plugin using various time-series components, but not the panel itself.
When we had similar requirements we decoupled time series panel from the core Grafana and updated it for our needs creating a custom plugin:
If you need basic Time Series or Bar graphs functionality check out the Apache ECharts panel, it allows to add elements directly on DOM and write JS code with events:
