Hey,
Using grafana 4.5.2 with Elasticsearch data source.
I am trying to create a table with 3 columns: #1:hostname, #2:network traffic in bits/sec, #3:network traffic out bits/sec
the data in the columns #1 is taken from the group by metric
the datas in columns #2 and #3 each is derivative of query average value of network bytes_recieved and bytes_sent respectively.
Currently I fail to implement it.
When using derivative the table is invalid.
The best implementation I succeeded to do is either display in/out traffic in single column or separate into two tables.
my question: how do I implement single table with values derivative (derivative over time, of last 5m data) as described above?
Currently implemented two tables of type “Time series to rows” tables.
Thanks
