For one of our customers we want to display/compare the temperature and humidity of two rooms via graph at four specific times a day.
The first problem we ve faced out were the specific measuring points (to compare the data with other sensors)
To solve the problem we have defined a new timeperiode in thruk:
Here is what we got so far:
Would you kindly advise if there are some other workarounds to get those specific measuring points?
The panel should approximately look like the table below:
It would be great if you can check if there are any other possibilities to solve this case.
Setup: Thruk 2.34-2 - OMD 3.30-labs-edition
Data Source: Nagflux
Thanks,
Julia
