I installed the https://github.com/NatelEnergy/grafana-discrete-panel plugin for grafana.
I have a metric in graphite that reports each time task ends, with the task duration as its value.
Is it possible to use discrete panel to illustrate that? any documentation on how to use it with graphite?
example?
Thanks
