Template information
Grafana v.8.1.4 running on my Ubuntu 20.04.3 LTS (Running on Pi4). Grafana runs as a container on docker.
I am trying to plot data from my SQLite-database to the Grafana Time Series Chart.
I am using the Grafana SQLite plugin to connect my SQLite database with Grafana. I am running Grafana as a container on docker, where I substituted the following flag to install the plugin:
-e "GF_INSTALL_PLUGINS=https://github.com/fr-ser/grafana-sqlite-datasource/releases/download/v2.1.1/frser-sqlite-datasource-2.1.1.zip;sqlite-datasource"
The query I used is as follows:
SELECT UnixTime, Open, High, Low, Close FROM Marketrecords
I have UnixTime set as the time formatted column.
What happened?
When the querry is run, it receives data. I can plot the data on a table or even inspect it with the query inspector or under the “explore” tab. So the data is, in fact, pulled - but somehow it’s not plotted on the time series panel. The Table-Panel, as well as the Gauge- and the Label-Panel all work as expected. See the screenshot:
I expected the Time Series Graph to plot the information querried.
Sure, this is the panel json. You can see the query in it as well.
No errors received.
No instructions followed so far. I just added the UnixTimestamp to my db and have been trying to use this as my time-column. It gets perceived as time-column, but it doesn’t change anything.
How do I get to plot the data on the Time Series Chart? ![]()
