Grafana server running but cant connect from local network
    Grafana 10.1.0 on a RPI.
    Connect to the grafana server from another computer in the local network.
    Grafana server is up and running on RPI, if I do sudo systemctl status grafana-server this is the output:
    grafana-server.service - Grafana instance
    Loaded: loaded (/usr/lib/systemd/system/grafana-server.service; enabled; vendor preset: enabled)
    Active: active (running) since Tue 2024-08-13 18:45:43 CST; 45s ago
    Docs: http://docs.grafana.org
    Main PID: 1828 (grafana)
    Tasks: 14 (limit: 2059)
    CGroup: /system.slice/grafana-server.service
    └─1828 /usr/share/grafana/bin/grafana server --config=/etc/grafana/grafana.ini --pidfile=/run/grafana/grafana-server.pid --packaging=deb cfg:default.paths.log
If I do netstat -lptn i get this line in the output:
tcp6 0 0 :::3000 :::* LISTEN -
If on a terminal on the RPI i do curl localhost:3000 I get:
Found.
But if I do curl 127.0.0.1:3000 I get:
curl: (7) Failed to connect to 127.0.0.1 port 3000: Connection refused
  • What happened?
    I try to connect to Grafana from another device in the local network by typing the RPI ip followed by :3000 and it shows connection refused. If I send a query to the RPI address without specifying a port it shows me the apache default page I have setup.
    I should be able to connect to grafana from any device in the local network by typing the RPI IP address in any browser.
    No errors, all seems to be working fine.
  • No.
Sorry this line should read:
Found
Sorry the system keeps changing my reply, I will insert spaces so it doesnt get changed
If I type in the terminal curl localhost:3000 I get
< a h r e f = “/login”>Found.
sounds like you might have some other server such as apache or another proxy running on that rpi?
change the grafana port to 7777 and restart grafana and hit that ip
