Dear all,
just after grafana 5.1.3 installation on CentOS7.4 , grafana server 1st start fails . See logs from systemd here enclosed. Next starts are all ok.
Don’t face this issue with same installation process and grafana 2.6 … will try with grafana 5.1.1 & 5.1.2.
Anyone did face same issue ? Thanks.
Best regards.
– Subject: Unit grafana-server.service has begun start-up
– Defined-By: systemd
– Support: http://lists.freedesktop.org/mailman/listinfo/systemd-devel
– Unit grafana-server.service has begun starting up.
Jun 13 11:29:16 i-00198358-grafana-server-15288818541.novalocal systemd[24005]: Failed at step RUNTIME_DIRECTORY spawning /usr/sbin/grafana-server: File exists
– Subject: Process /usr/sbin/grafana-server could not be executed
– The process /usr/sbin/grafana-server could not be executed and failed.
– The error number returned by this process is 17.
Jun 13 11:29:16 i-00198358-grafana-server-15288818541.novalocal systemd[1]: grafana-server.service: main process exited, code=exited, status=233/RUNTIME_DIRECTORY
Jun 13 11:29:16 i-00198358-grafana-server-15288818541.novalocal systemd[1]: Failed to start Grafana instance.
