I am using Garafana to display some Asset data from InfluxDB. The table in InfluxDB look like this (timestamp excluded):
================================ | Device | Parameter | Value | ================================ | 1 | Name | ABC | | 1 | Firmware | 123 | | 1 | Serial No | XYZ | | 1 | Type | ABC12 | | 2 | Name | DEF | | 2 | Firmware | 456 | | 2 | Serial No | UVW | | 2 | Type | DEF45 | ================================
I want to show the Parameters as column name
==================================================== | Device | Name | Firmware | Serial No | Type | ==================================================== | 1 | ABC | 123 | XYZ | ABC12 | | 2 | DEF | 456 | UVW | DEF45 | ====================================================
How can I achieve this with the table widget in Grafana?
Thanks in advance.
Cheers,
Subhadeep Datta
