9.3
integrate Grafana opensource with Azure AD with Oauth2 -
did everything thats in the documentation but it keeps giving different errors after clicking on sign in with Microsoft. the latest was 404 File or directory not found error. after clicking on sign in with Microsoft -the redirection is not working. -
What happened?
it keeps giving different errors after clicking on sign in with Microsoft. the latest was 404 File or directory not found error. after clicking on sign in with Microsoft -the redirection is not working to the actual URL.
load an Azure authentication page -
404 file or directory not found error
Log
redirecting to local host (
/65dxxxx-dxxx-4cxx-aXXX-2ceyyy8YYYb/oauth2/v2.0/authorize?client_id=a3XXyy-075a-XXXX-9YYX-7dXXYY78deyyy&redirect_uri=http%3A%2F%2Flocalhost%3A3000%2Fgrafana%2Flogin%2Fazuread&response_type=code&scope=openid+email+profile&state=7vAvM3p==================z_iKRYUZGoIM%3D
- Did you follow any online instructions? If so, what is the URL?
Configure Azure AD OAuth2 authentication | Grafana documentation
