I´m trying to login into my Grafana v5.2.3 with a Oauth2 login in Azure Active Directory. I read the grafana documentation with the steps but when i finished i have this error:
Grafana is hosted in a virtual machine on azure running with linux.
When I check the grafana log:
t=2018-09-21T14:44:16+0000 lvl=eror msg=login.OAuthLogin(NewTransportWithCode) logger=context userId=0 orgId=0 uname= error=“oauth2: cannot fetch token: 400 Bad Request\nResponse: {"error":"invalid_resource","error_description":"AADSTS50001: Resource identifier is not provided.\r\nTrace ID: 1743d4f7-9435-42ad-85f5-1579014f2a00\r\nCorrelation ID: 721f9842-b3f5-4cee-989b-d560f5fed47a\r\nTimestamp: 2018-09-21 14:44:16Z","error_codes":[50001],"timestamp":"2018-09-21 14:44:16Z","trace_id":"1743d4f7-9435-42ad-85f5-1579014f2a00","correlation_id":"721f9842-b3f5-4cee-989b-d560f5fed47a"}”
My config is:
#################################### Server ####################################
[server]
# Protocol (http or https)
protocol = https
# The ip address to bind to, empty will bind to all interfaces
http_addr = 0.0.0.0
# The http port to use
http_port = 3000
# The public facing domain name used to access grafana from a browser
domain = mydomain.com
# Redirect to correct domain if host header does not match domain
# Prevents DNS rebinding attacks
;enforce_domain = false
# The full public facing url you use in browser, used for redirects and emails
# If you use reverse proxy and sub path specify full url (with sub path)
root_url = %(protocol)s://%(domain)s:%(http_port)s/
# Log web requests
;router_logging = false
# the path relative working path
;static_root_path = public
# enable gzip
;enable_gzip = false
Any idea of what I’m doing wrong?
