Hi!
I’ve been trying to make the authorization with the Azure Active Directory and all that I could get is the same error…
The log give me this information:
t=2018-09-26T13:17:05+0000
lvl=eror
msg=login.OAuthLogin(NewTransportWithCode)
logger=context
userId=0
orgId=0
uname=
error="oauth2: cannot fetch token: 400 Bad Request
Response: “error”:“invalid_resource”,
“error_description”:"AADSTS50001: Resource identifier is not provided.
nTrace ID: ed53af0d-4a05-4c3e-88f6-7d2c74aec900
nCorrelation ID: b3208f25-c532-4e2b-a020-75878d69e5bf
“nTimestamp”: “2018-09-26 13:17:05Z”,
“error_codes”:[50001],
“timestamp”:“2018-09-26 13:17:05Z”,
“trace_id”:“ed53af0d-4a05-4c3e-88f6-7d2c74aec900”,
“correlation_id”:“b3208f25-c532-4e2b-a020-75878d69e5bf”
I set the response URL on my application in the AAD with HTTP and HTTPS (just in case).
Also my grafana configuration is:
VERSION: v5.2.3
#################################### Server ####################################
[server]
Protocol (http or https)
protocol = https
The ip address to bind to, empty will bind to all interfaces
http_addr = 0.0.0.0
The http port to use
http_port = 3000
The public facing domain name used to access grafana from a browser
domain = grafanadomain.com
Redirect to correct domain if host header does not match domain
Prevents DNS rebinding attacks
;enforce_domain = false
The full public facing url you use in browser, used for redirects and emails
If you use reverse proxy and sub path specify full url (with sub path)
root_url = %(protocol)s://%(domain)s:%(http_port)s/
Log web requests
;router_logging = false
the path relative working path
;static_root_path = public
enable gzip
;enable_gzip = false
https certs & key file
Anyone have anyidea how could I fix this?
Thank you so much in advance.
