Grafana MySQL Inbuild database
I’ve been using Grafana for long time,like it but now I found the Grafana cloud App.I’m very onteresting about it but I am trying to using inbuilt mySQL database and can not find is it possible or not.Is there any option to use it?
Sorry if the inquiey is not for here or already exists.
Best regards!
Are you trying to use mysql datasource for visualizing metrics and the mysql is not accessible from Grafana cloud? You’ll need to make your mysql instance publicly available. Should be easier and more secure if you host mysql instance in Amazon cloud for example.
Grafana publishes a list of source IPs for hosted Grafana, but they say that it is not always 100% accurate which is kind of silly.
https://grafana.com/api/hosted-grafana/source-ips
