Grafana cloud, allow_embedding and mysql connection
Hi All,
I have just been doing some testing of Grafana for the dashboard need of our company and it looks quite promising. I just had a couple of questions that were a bit unclear that I was hoping somebody would be able to help me with.
In our company we have a local mysql instance which hosts all the data. We want to serve this data on dashboards internally and externally. For the internal dashboards I can just use our local grafana instance, but for the external sharing I am thinking about using the Grafana cloud.
To be able to get any dashboard to work in the cloud I will need to make sure the cloud instance has the ability to see my local mysql server. I don’t really want to make my server directly visible to the network since would cause a lot of security issues. Does anybody have any guidance on other options?
Also I will need to make sure I can embed my Grafana dashboards in other web pages. The documantation is very clear on how to allow embedding in the local version, but I have not been able to find anything on how to do this in the cloud version. Does anybody know how to allow embedding in the cloud version?
Kind Regards,
Hilbert
kindly let me know if you got any updates on your issue? as its similar to our case here. Thank you
