Grafana - monitoring SSL
I’m trying to create monitoring of SSL using prometheus and grafana.
Everything is almost all right except…
How can I narrow my query to show only last answers not all since the beggining?
Or maybe there is some plugin ( I think I checked everyone related to my problem) which can do this ?
I just want to have simple table with 2 columns : expiration time and url.
Best regards,
Morbious
Make sure you check the Instant checkbox for query. Then it will behave like the table view in Prometheus UI, i.e. showing the “current value”. See demo.
Thank you very much - that does the job.
