Grafana version is 10.0.3 and OS is Ubuntu
Create alert system for the list of domains under the jobs in prometheus -
Add the all the targets in the prometheus job. Then with the help of blackbox exporter collected the SSL expiry date of those domains. Create alert if the days are less than 21 -
What happened?
If the promethus scraping interval is 10m I can see the list of targets inside the job -
I want the scraping interval should be 1day -
- job_name: ‘ssl-certificate’
sample_limit: 100
metrics_path: /probe
params:
module: [ssl]
scrape_interval: 1d
static_configs:- targets:
AnySnap.app -
