We’re experiencing some issues with our grafana agent (prometheus) scraping configuration. If we set the scrape_interval to 15s or 30s, everything is working fine but once we increase it to 60s it stops scraping our kubernetes-pods job from the configuration below. Is there anything additional we need to change in the configuration to make 60s work? We initially deployed the agent when the 15s scrape interval was still the default setting.
kind: ConfigMap
metadata:
namespace: ${NAMESPACE}
apiVersion: v1
data:
agent.yaml: |
server:
http_listen_port: 12345
prometheus:
global:
scrape_interval: 60s
external_labels:
cluster: cloud
configs:
- name: integrations
remote_write:
- url: ${REMOTE_WRITE_URL}
basic_auth:
username: ${REMOTE_WRITE_USERNAME}
password: ${REMOTE_WRITE_PASSWORD}
scrape_configs:
- job_name: kubernetes-pods
kubernetes_sd_configs:
- role: pod
relabel_configs:
- action: keep
regex: .*-metrics
source_labels:
- __meta_kubernetes_pod_container_port_name
metric_relabel_configs:
- source_labels: [__name__]
regex: 'nginx_ingress_controller_(request_duration_seconds_bucket|response_duration_seconds_bucket|request_duration_seconds_count|response_duration_seconds_sum|upstream_latency_seconds_sum|upstream_latency_seconds_countrequests|ssl_expire_time_seconds|nginx_process_connections|requests)'
action: keep
