I took a default configuration from the documentation on installing grafana-agent in static mode and then set it to accept secrets via env vars along with run in debug mode. Those bits all seem to work and I can see agent and node_exporter metrics in the cloud grafana instance.
I’m trying to scrape a custom exporter running on localhost:8080. I attempted to put it under metrics.configs in the integrations job’s scrape_configs. I’ve put it in debug mode and have been tailing the journal logs and do not see it ever actually attempting to scrape the solana-exporter.
I am seeing some lines that tell me it sees it in the config but doesn’t see a valid config to scrape I think?
Feb 23 03:12:41 [hostname here] grafana-agent[1860593]: ts=2024-02-23T03:12:41.27045376Z caller=manager.go:287 level=debug agent=prometheus instance=b2ab4d993b48b18b4d24abd693c65b13 component="discovery manager" msg="Starting provider" provider=static/0 subs=map[solana-exporter:{}]
I’m new to prometheus and grafana-agent config, but am not new to unix. This would be trivial with the datadog agent but has been frustratingly difficult to debug the grafana-agent. Any context or pointers in the right direction would be very much appreciated!
Agent Details
Installed from the ubuntu repo.
grafana-agent --version
agent, version v0.39.1 (branch: HEAD, revision: 7dbb39c7)
build user: root@e5705ffdf6fa
build date: 2024-01-19T11:55:16Z
go version: go1.21.4
platform: linux/amd64
tags: netgo,builtinassets,promtail_journal_enabled
Configuration
Located at /etc/grafana-agent.yaml
# For a full configuration reference, see: https://grafana.com/docs/agent/latest/configuration/.
# Parts from: https://storage.googleapis.com/cloud-onboarding/agent/config/config.yaml
server:
log_level: debug
integrations:
agent:
enabled: true
relabel_configs:
- action: replace
source_labels:
- agent_hostname
target_label: instance
- action: replace
target_label: job
metric_relabel_configs:
- action: keep
regex: (prometheus_target_.*|prometheus_sd_discovered_targets|agent_build.*|agent_wal_samples_appended_total|process_start_time_seconds)
source_labels:
- __name__
node_exporter:
enabled: true
include_exporter_metrics: true
#disable_collectors:
# - "mdadm"
# Not enabled by default per the docs
enable_collectors:
- "systemd"
systemd_enable_restarts_metrics: true
# Collects metrics from any files in this directory matching the glob *.prom.
# The files must use the prometheus exposition text file format as documented:
# https://prometheus.io/docs/instrumenting/exposition_formats
textfile_directory: /etc/grafana-agent/textfiles.d
prometheus_remote_write:
- basic_auth:
password: ${GRAFANA_AGENT_PROMETHEUS_REMOTE_WRITE_PASSWORD}
username: ${GRAFANA_AGENT_PROMETHEUS_REMOTE_WRITE_USERNAME}
url: ${GRAFANA_AGENT_PROMETHEUS_REMOTE_WRITE_URL}
logs:
configs:
- clients:
- basic_auth:
password: ${GRAFANA_AGENT_LOGS_PASSWORD}
username: ${GRAFANA_AGENT_LOGS_USERNAME}
url: ${GRAFANA_AGENT_LOGS_URL}
positions:
filename: /tmp/positions.yaml
scrape_configs:
metrics:
configs:
- name: integrations
remote_write:
- basic_auth:
password: ${GRAFANA_AGENT_METRICS_REMOTE_WRITE_PASSWORD}
username: ${GRAFANA_AGENT_METRICS_REMOTE_WRITE_USERNAME}
url: ${GRAFANA_AGENT_METRICS_REMOTE_WRITE_URL}
scrape_configs:
- job_name: solana-exporter
metrics_path: /metrics
static_configs:
- labels: {env: prod, network: mainnet}
targets: ['localhost:8080']
global:
scrape_interval: 1m
wal_directory: /var/lib/grafana-agent
