Grafana version = v0.43.2
OS = Oracle LINUX 80 -
I am new to Grafana and trying to understand the Grafana Static Agent configuration file. I understand that Grafana Alloy is the new version but before I switch to Alloy, I would like to understand how Grafana Static Configuration works.
While I understand what metrics “node_exporter” integration collects, I am trying to understand what metrics the “agent” integration collects. According to Grafana documentation:
“the agent integration collects metrics from that running instance of the Grafana Agent.”
So, what are those agent metrics and and how I can display them?
What happened?
integrations:
agent:
enabled: true
instance: “agent-integration-instance”
scrape_integration: true
node_exporter:
enabled: true
instance: “node-exporter-integration-instance”
Configure static mode | Grafana Agent documentation
