v11.3.2 on Linux
- What are you trying to achieve?
I want to use an Expression to perform a calculation from a Sum Query which might have yielded empty results: $A / ($A + $B), where $B may have no data.
It’s an Elasticsearch query, so I can’t specify COALESCE or UNION. I don’t think there’s any trick I can do in the query.
- How are you trying to achieve it?
I’m trying two Sum Queries A and B which both look approximately like this:
- Query type > Metrics
- Lucene Query >
field_a : true - Metric > Sum >
field_x - Group By > Terms >
field_y
I have an Expression $Exp1 to identify whether $B is empty:
- Operation > Classic condition (legacy)
- WHEN
count()OF$BHAS NO VALUE
And I have another Expression $Exp2, which I want to display in a Gauge visualization:
$A / ($A + ( ( 1 - $Exp1 ) * $B ) )
- What happened?
When displaying $Exp2, the Gauge shows ‘no data’. However, when displaying $Exp1, the Gauge shows 1.
I expected (1 - $Exp) to evaluate to 0 in this case and make the expression equal $A / ($A + 0), and therefore display a value of 1 in the Gauge.
- Can you copy/paste the configuration(s) that you are having problems with?
(I can’t share this. It’s for my employer, and we don’t share anything that references our database or code.)
- Did you receive any errors in the Grafana UI or in related logs? If so, please tell us exactly what they were.
I get a red warning icon. Hovering over it says ‘Query error: 500’. I’ve checked and re-checked this so many times. I’ve typed it correctly; I just can’t reference my ‘Classic condition’ expression within another expression without getting this error.
- Did you follow any online instructions? If so, what is the URL?
No, I have no instructions
You might advise me to just change the ‘No value’ option to the value that I want like so many related pages have advised. But that won’t satisfy my use case because I actually need to set this up for additional Queries as operands which might be empty, and I need to use different behaviour for cases where different operands are empty.
