Grafana Labs automatically gets log out
Hii everyone,
I am using Grafana dashboards to show the various data structures on the building tv. When I used the time-series visualization, it works fine. But when I added any other visualization like pie chart, stat, bar chart etc. It automatically gets log out after some time. What is the reason behind that and How can I solve this issue?
Any help would be appreciated. Thank you for your time and help.
Best regards,
Parth Suhagiya
Hi @parthrsuhagiya,
Thanks for opening this post.
Please review the submission template and include more details:
  • What is your datasource?
  • What visualization panel you are using e.g. time-series, bar chart, histogram etc?
  • What happened?
