I have the latest versions of Grafana and InfluxDB
Grafana 7.0.1
InfluxDB 1.8.0
Which versions, please (both Safari and OSX)?
Safari 13.1
OSX 10.15.4
But when I use Chrome or Chromium
Chromium 78.0.3904.108 on Raspbian 10 (buster)
Chrome 83.0.4103.61 on OSX
Chrome 81.0.4044.129 on Ubuntu 20.04 LTS
Chrome 83.0.4103.61 on Windows 10 Home Version 1909
Have you tried any other browser such as Firefox, Edge, or even IE?
I’ve tried Firefox ESR on Raspbian and Firefox on Ubuntu with the same behavior.
Do you know whether it has been going on since you:
a) installed Grafana and started using it at all
It worked for a few months with now problems.
b) upgraded Grafana to some more recent version than the one which last worked without this problem
It could have been caused by a Grafana update but I thought it was a Chrome problem since it continued to work on Safari.
c) upgraded your MacBook (either OSX or specifically Safari) to some version which no longer has the problem
The problem has never happened on Safari.
d) upgraded your Chrome/ium versions on the other machine to something which now does have the problem?
I wish I could correlate it to a specific Chrome/Chromium/Grafana/InfluxDB/Rasbian update but it’s been happening for so long that I can’t. I even switched from a Pi 3B to a 4 to make sure it wasn’t a hardware problem.
Let me know how and I’ll upload the Grafana log file that shows the “Successful Logouts”.
Thanks for the help.
