grafana in local.
grafana logout soon.
i check it, the config file and i think is good , i have 7d days on time of sesion, but the grafana logout before this time, now know the time exactaly maybe minutes less than 1 hour i think.
i up the time of database, i think the default time is 14440 seconds…
i need the dassboard show the info 8 hours more or less…without logout…
thanks.
What happened?
