- com.docker.compose.version 2.39.4
I use it on a Oracle ARM instance
- Getting it to show the correct network usage.
Network Download
sum by (instance) (irate(node_network_receive_bytes_total{
job=“node”, instance=“$instance”,
device=~“^(enp|ens|eno|eth|bond|wlp).*”
}[$__rate_interval]) * 8
Network Upload
sum by (instance) (irate(node_network_transmit_bytes_total{
job="node", instance="$instance", device=\~"^(enp|ens|eno|eth|bond|wlp).\*"}[$__rate_interval]) * 8
What happened?
It only shows :
Down: 725 b/s
Up: 7.29 kb/s
even if there is a stream running -
Show the correct network usage -
I guess it’s this part-
Network Download
Network Upload
My compose file:
services:
plex:
image: lscr.io/linuxserver/plex:latest
container_name: plex_nostop
hostname: plex
environment:
- PUID=${PUID}
- PGID=${GUID}
- TZ=${TZ}
- VERSION=docker
- PLEX_CLAIM=claim-7Jf5T8R8pSwmUsQX7Fyy
ports:
- 32400:32400
tmpfs:
- /transcode:size=8G
volumes:
- ${DOCKERCONFDIR}/plex:/config
- ${SOURCEPATH}:/media
restart: unless-stopped
healthcheck:
test: curl --connect-timeout 15 --silent --show-error --fail http://localhost:32400/identity
interval: 1m
timeout: 30s
retries: 3
start_period: 1m
prometheus-plex-exporter:
container_name: prometheus-plex-exporter
image: ghcr.io/timothystewart6/prometheus-plex-exporter:latest
pull_policy: always
depends_on:
- plex
env_file:
- /home/ubuntu/docker/data/plexmonitoring/plex-prometheus-exporter/.env
\# ports:
\# - 9000:9000/tcp
security_opt:
- no-new-privileges:true
prometheus:
image: prom/prometheus:latest
pull_policy: always
extra_hosts:
- "host.docker.internal:host-gateway" # Allows access to host network from container
env_file:
- /home/ubuntu/docker/data/plexmonitoring/prometheus/.env
user: "1001:1001"
ports:
- 9090:9090/tcp
security_opt:
volumes:
- ${PLEX_MONITOR}/prometheus/config/prometheus.yml:/etc/prometheus/prometheus.yml:ro
- ${PLEX_MONITOR}/prometheus/config/rules:/etc/prometheus/rules:ro
- ${PLEX_MONITOR}/prometheus/data/:/prometheus
command:
- --config.file=/etc/prometheus/prometheus.yml
- --storage.tsdb.path=/prometheus
- --storage.tsdb.retention.time=30d
- --web.enable-lifecycle
- --web.enable-admin-api
node_exporter:
image: quay.io/prometheus/node-exporter:latest
container_name: node_exporter
hostname: node_exporter
pull_policy: always
#network_mode: host
env_file:
- /home/ubuntu/docker/data/plexmonitoring/node-exporter/.env
ports:
- 9100:9100
security_opt:
command:
- '--path.rootfs=/host'
- '--path.procfs=/host/proc'
- '--path.sysfs=/host/sys'
- '--collector.cpu.info'
pid: host
volumes:
- /:/host:ro,rslave
- /proc:/host/proc:ro
- /sys:/host/sys:ro
grafana:
image: grafana/grafana:latest
container_name: grafana
pull_policy: always
depends_on:
- prometheus
env_file:
- /home/ubuntu/docker/data/plexmonitoring/grafana/.env
user: "1001:1001"
ports:
- 3000:3000/tcp
security_opt:
volumes:
- ${PLEX_MONITOR}/grafana/data:/var/lib/grafana
- ${PLEX_MONITOR}/grafana/provisioning/datasources:/etc/grafana/provisioning/datasources
- ${PLEX_MONITOR}/grafana/provisioning/dashboards:/etc/grafana/provisioning/dashboards
cadvisor:
image: gcr.io/cadvisor/cadvisor:latest
container_name: cadvisor
pull_policy: always
env_file:
- /home/ubuntu/docker/data/plexmonitoring/cadvisor/.env
volumes:
- /:/rootfs:ro
- /var/run:/var/run:ro
- /sys:/sys:ro
- /var/lib/docker/:/var/lib/docker:ro
- /dev/disk/:/dev/disk:ro
networks:
default:
external: true
The tutorial is found here: timothystewart6/plex-monitoring-stack: A Plex Stack with Monitoring
My vnstat shows these
