Trying to monitor network traffic from my Cisco switch on my trunk port. I got data from the switch and interfaces.
Using Prometheus and Telegraf.
Got this query: irate(interface_ifInOctets{ifDescr="GigabitEthernet2/0/47"}[2m]) *8 / 1024
I dont have this ifHCInOctets option - that i see mentioned else where.
My dashboard does not say: no data in response.
So it igot data from the switch, but its not showing anyt in the Dashboard
Hope someone can help :slight_smile:
* Grafana Version 8.1.3?
Here is my Telegraf configuration for that switch:
[[inputs.snmp]]
agents = ["udp://IPv4:161"]
# ## Timeout for each request.
timeout = "5s"
# ## SNMP version; can be 1, 2, or 3.
version = 2
# ## SNMP community string.
community = "Communitystring"
# ## Number of retries to attempt.
retries = 3
[[inputs.snmp.field]]
name = "hostname"
oid = "RFC1213-MIB::sysName.0"
is_tag = true
# IF-MIB::ifTable contains counters on input and output traffic as well as errors and discards.
[[inputs.snmp.table]]
name = "interface"
inherit_tags = [ "hostname" ]
oid = "IF-MIB::ifTable"
#Interface tag - used to identify interface in metrics database
[[inputs.snmp.table.field]]
name = "ifDescr"
oid = "IF-MIB::ifDescr"
is_tag = true
name = "ifAlias"
oid = "IF-MIB::ifAlias"
is_tag = true
have you tried Grafana 8.2.1 to see if this got resolved? Number of influx-related PRs in the changelog between your version and the latest
