SNMP Network Speed to Grafana
I’m trying to monitor my edgerouters networkspeed.
My setup is: Edgerouter → SNMP → Telegraf → InfluxDB → Grafana
Versions:
Telegraf: 1.24.3
InfluxDB: v2.5.1
Grafana: v9.2.6
My first plan is to get current bandwith from the edgerouter (ER-8) to the InfluxDB but I think thats not the right way. (I think there is only some kind of packetcounter)
I found this instruction, but I don’t get really along with that.
Getting the snmp data to the InfluxDB works.
So I think the better way is to collect the packet statics and count them to bits per second in the grafana web ui using Flux query language.
If I’m wrong, please correct me.
Snmp part of the configfile:
[[inputs.snmp.field]]
  name = "ubnt-er8-LAN-in"
  oid = "iso.3.6.1.2.1.2.2.1.10.5" # LAN - input
  name = "ubnt-er8-LAN-out"
  oid = "iso.3.6.1.2.1.2.2.1.16.5" # LAN - out
  name = "ubnt-er8-UPLINK-in"
  oid = "iso.3.6.1.2.1.2.2.1.10.7" # UPLINK - in
  name = "ubnt-er8-UPLINK-out"
  oid = "iso.3.6.1.2.1.2.2.1.16.7" # UPLINK - out
My knowledge abou flux is not really much…
My final question is, if anyone of you does have a solution?
Thanks.
Welcome
Can you please post a sampling of data as inline csv? Bucket name,measurement and following
Metric,value,datetime
Packet,33.3,2022-12-03
Sure:
#group,false,false,true,true,false,false,true,true,true,true
#datatype,string,long,dateTime:RFC3339,dateTime:RFC3339,dateTime:RFC3339,double,string,string,string,string
#default,mean,,,,,,,,,
,result,table,_start,_stop,_time,_value,_field,_measurement,host,ubnt-er8
,,0,2022-12-02T13:52:56.748916101Z,2022-12-02T14:52:56.748916101Z,2022-12-02T14:51:30Z,239268658,ubnt-er8-UPLINK-in,snmp,snmp-agent,[edgerouters IP]
,,0,2022-12-02T13:52:56.748916101Z,2022-12-02T14:52:56.748916101Z,2022-12-02T14:51:40Z,239270142,ubnt-er8-UPLINK-in,snmp,snmp-agent,[edgerouters IP]
,,0,2022-12-02T13:52:56.748916101Z,2022-12-02T14:52:56.748916101Z,2022-12-02T14:51:50Z,239273287,ubnt-er8-UPLINK-in,snmp,snmp-agent,[edgerouters IP]
,,0,2022-12-02T13:52:56.748916101Z,2022-12-02T14:52:56.748916101Z,2022-12-02T14:52:00Z,239274341,ubnt-er8-UPLINK-in,snmp,snmp-agent,[edgerouters IP]
,,0,2022-12-02T13:52:56.748916101Z,2022-12-02T14:52:56.748916101Z,2022-12-02T14:52:10Z,239276741,ubnt-er8-UPLINK-in,snmp,snmp-agent,[edgerouters IP]
,,0,2022-12-02T13:52:56.748916101Z,2022-12-02T14:52:56.748916101Z,2022-12-02T14:52:20Z,239278067,ubnt-er8-UPLINK-in,snmp,snmp-agent,[edgerouters IP]
,,0,2022-12-02T13:52:56.748916101Z,2022-12-02T14:52:56.748916101Z,2022-12-02T14:52:30Z,239278963,ubnt-er8-UPLINK-in,snmp,snmp-agent,[edgerouters IP]
,,0,2022-12-02T13:52:56.748916101Z,2022-12-02T14:52:56.748916101Z,2022-12-02T14:52:40Z,239280243,ubnt-er8-UPLINK-in,snmp,snmp-agent,[edgerouters IP]
,,0,2022-12-02T13:52:56.748916101Z,2022-12-02T14:52:56.748916101Z,2022-12-02T14:52:50Z,239283354,ubnt-er8-UPLINK-in,snmp,snmp-agent,[edgerouters IP]
Can you please provide a small sampling of in/out for all data pairs? What you posted is the same data point. The idea is for us to emulate your data in our influxdb .
The 236363737 value is what?
That’s the Value from:
The OID: .1.3.6.1.2.1.2.2.1.10.5 is a Counter32 of LAN input, called: IfInOctets.5
This
That the CSV with all 2 Interfaces in both directions:
,,0,2022-11-28T07:26:31.098514791Z,2022-12-05T07:26:31.098514791Z,2022-11-30T11:00:00Z,94231250.05940594,ubnt-er8-LAN-in,snmp,snmp-agent,192.168.100.1
,,0,2022-11-28T07:26:31.098514791Z,2022-12-05T07:26:31.098514791Z,2022-11-30T11:30:00Z,102804047.1388889,ubnt-er8-LAN-in,snmp,snmp-agent,192.168.100.1
,,0,2022-11-28T07:26:31.098514791Z,2022-12-05T07:26:31.098514791Z,2022-11-30T12:00:00Z,106633123.91111112,ubnt-er8-LAN-in,snmp,snmp-agent,192.168.100.1
,,0,2022-11-28T07:26:31.098514791Z,2022-12-05T07:26:31.098514791Z,2022-11-30T12:30:00Z,112841736.72222222,ubnt-er8-LAN-in,snmp,snmp-agent,192.168.100.1
,,0,2022-11-28T07:26:31.098514791Z,2022-12-05T07:26:31.098514791Z,2022-11-30T13:00:00Z,114616341.71666667,ubnt-er8-LAN-in,snmp,snmp-agent,192.168.100.1
,,0,2022-11-28T07:26:31.098514791Z,2022-12-05T07:26:31.098514791Z,2022-11-30T13:30:00Z,115759688.16111112,ubnt-er8-LAN-in,snmp,snmp-agent,192.168.100.1
,,0,2022-11-28T07:26:31.098514791Z,2022-12-05T07:26:31.098514791Z,2022-11-30T14:00:00Z,116929816.70555556,ubnt-er8-LAN-in,snmp,snmp-agent,192.168.100.1
,,0,2022-11-28T07:26:31.098514791Z,2022-12-05T07:26:31.098514791Z,2022-11-30T14:30:00Z,118097935.16111112,ubnt-er8-LAN-in,snmp,snmp-agent,192.168.100.1
,,0,2022-11-28T07:26:31.098514791Z,2022-12-05T07:26:31.098514791Z,2022-11-30T15:00:00Z,122146589.51111111,ubnt-er8-LAN-in,snmp,snmp-agent,192.168.100.1
,,0,2022-11-28T07:26:31.098514791Z,2022-12-05T07:26:31.098514791Z,2022-11-30T15:30:00Z,127985081.17222223,ubnt-er8-LAN-in,snmp,snmp-agent,192.168.100.1
,,0,2022-11-28T07:26:31.098514791Z,2022-12-05T07:26:31.098514791Z,2022-11-30T16:00:00Z,128944815.10071942,ubnt-er8-LAN-in,snmp,snmp-agent,192.168.100.1
,,0,2022-11-28T07:26:31.098514791Z,2022-12-05T07:26:31.098514791Z,2022-12-02T07:30:00Z,352361.67741935485,ubnt-er8-LAN-in,snmp,snmp-agent,192.168.100.1
,,0,2022-11-28T07:26:31.098514791Z,2022-12-05T07:26:31.098514791Z,2022-12-02T08:00:00Z,2007592.861111111,ubnt-er8-LAN-in,snmp,snmp-agent,192.168.100.1
,,0,2022-11-28T07:26:31.098514791Z,2022-12-05T07:26:31.098514791Z,2022-12-02T08:30:00Z,2840247489.4722223,ubnt-er8-LAN-in,snmp,snmp-agent,192.168.100.1
,,0,2022-11-28T07:26:31.098514791Z,2022-12-05T07:26:31.098514791Z,2022-12-02T09:00:00Z,4017896261.661111,ubnt-er8-LAN-in,snmp,snmp-agent,192.168.100.1
,,0,2022-11-28T07:26:31.098514791Z,2022-12-05T07:26:31.098514791Z,2022-12-02T09:30:00Z,4021864052.6833334,ubnt-er8-LAN-in,snmp,snmp-agent,192.168.100.1
,,0,2022-11-28T07:26:31.098514791Z,2022-12-05T07:26:31.098514791Z,2022-12-02T10:00:00Z,4024337865.772222,ubnt-er8-LAN-in,snmp,snmp-agent,192.168.100.1
,,0,2022-11-28T07:26:31.098514791Z,2022-12-05T07:26:31.098514791Z,2022-12-02T10:30:00Z,4026818715.016667,ubnt-er8-LAN-in,snmp,snmp-agent,192.168.100.1
,,0,2022-11-28T07:26:31.098514791Z,2022-12-05T07:26:31.098514791Z,2022-12-02T11:00:00Z,4028876713.788889,ubnt-er8-LAN-in,snmp,snmp-agent,192.168.100.1
,,0,2022-11-28T07:26:31.098514791Z,2022-12-05T07:26:31.098514791Z,2022-12-02T11:30:00Z,4031062239.3166666,ubnt-er8-LAN-in,snmp,snmp-agent,192.168.100.1
,,0,2022-11-28T07:26:31.098514791Z,2022-12-05T07:26:31.098514791Z,2022-12-02T12:00:00Z,4033540058.9722223,ubnt-er8-LAN-in,snmp,snmp-agent,192.168.100.1
,,0,2022-11-28T07:26:31.098514791Z,2022-12-05T07:26:31.098514791Z,2022-12-02T12:30:00Z,4036112177.85,ubnt-er8-LAN-in,snmp,snmp-agent,192.168.100.1
,,0,2022-11-28T07:26:31.098514791Z,2022-12-05T07:26:31.098514791Z,2022-12-02T13:00:00Z,4038655490.7,ubnt-er8-LAN-in,snmp,snmp-agent,192.168.100.1
,,0,2022-11-28T07:26:31.098514791Z,2022-12-05T07:26:31.098514791Z,2022-12-02T13:30:00Z,4042766652.2055554,ubnt-er8-LAN-in,snmp,snmp-agent,192.168.100.1
,,0,2022-11-28T07:26:31.098514791Z,2022-12-05T07:26:31.098514791Z,2022-12-02T14:00:00Z,4045897121.9,ubnt-er8-LAN-in,snmp,snmp-agent,192.168.100.1
,,0,2022-11-28T07:26:31.098514791Z,2022-12-05T07:26:31.098514791Z,2022-12-02T14:30:00Z,4048129942.883333,ubnt-er8-LAN-in,snmp,snmp-agent,192.168.100.1
,,0,2022-11-28T07:26:31.098514791Z,2022-12-05T07:26:31.098514791Z,2022-12-02T15:00:00Z,4049735982.2611113,ubnt-er8-LAN-in,snmp,snmp-agent,192.168.100.1
,,0,2022-11-28T07:26:31.098514791Z,2022-12-05T07:26:31.098514791Z,2022-12-02T15:30:00Z,4050622246,ubnt-er8-LAN-in,snmp,snmp-agent,192.168.100.1
,,0,2022-11-28T07:26:31.098514791Z,2022-12-05T07:26:31.098514791Z,2022-12-05T07:26:31.098514791Z,3344713.834782609,ubnt-er8-LAN-in,snmp,snmp-agent,192.168.100.1
,,1,2022-11-28T07:26:31.098514791Z,2022-12-05T07:26:31.098514791Z,2022-11-30T11:00:00Z,585868093.1485149,ubnt-er8-LAN-out,snmp,snmp-agent,192.168.100.1
,,1,2022-11-28T07:26:31.098514791Z,2022-12-05T07:26:31.098514791Z,2022-11-30T11:30:00Z,1509176924.3555555,ubnt-er8-LAN-out,snmp,snmp-agent,192.168.100.1
,,1,2022-11-28T07:26:31.098514791Z,2022-12-05T07:26:31.098514791Z,2022-11-30T12:00:00Z,1884607162.0833333,ubnt-er8-LAN-out,snmp,snmp-agent,192.168.100.1
,,1,2022-11-28T07:26:31.098514791Z,2022-12-05T07:26:31.098514791Z,2022-11-30T12:30:00Z,2578668358.9888887,ubnt-er8-LAN-out,snmp,snmp-agent,192.168.100.1
,,1,2022-11-28T07:26:31.098514791Z,2022-12-05T07:26:31.098514791Z,2022-11-30T13:00:00Z,2609230050.0055556,ubnt-er8-LAN-out,snmp,snmp-agent,192.168.100.1
,,1,2022-11-28T07:26:31.098514791Z,2022-12-05T07:26:31.098514791Z,2022-11-30T13:30:00Z,2611000599.7777777,ubnt-er8-LAN-out,snmp,snmp-agent,192.168.100.1
,,1,2022-11-28T07:26:31.098514791Z,2022-12-05T07:26:31.098514791Z,2022-11-30T14:00:00Z,2612825865.4,ubnt-er8-LAN-out,snmp,snmp-agent,192.168.100.1
,,1,2022-11-28T07:26:31.098514791Z,2022-12-05T07:26:31.098514791Z,2022-11-30T14:30:00Z,2614426436.2777777,ubnt-er8-LAN-out,snmp,snmp-agent,192.168.100.1
,,1,2022-11-28T07:26:31.098514791Z,2022-12-05T07:26:31.098514791Z,2022-11-30T15:00:00Z,2619863691.388889,ubnt-er8-LAN-out,snmp,snmp-agent,192.168.100.1
,,1,2022-11-28T07:26:31.098514791Z,2022-12-05T07:26:31.098514791Z,2022-11-30T15:30:00Z,2624696088.288889,ubnt-er8-LAN-out,snmp,snmp-agent,192.168.100.1
,,1,2022-11-28T07:26:31.098514791Z,2022-12-05T07:26:31.098514791Z,2022-11-30T16:00:00Z,2625994444.9064746,ubnt-er8-LAN-out,snmp,snmp-agent,192.168.100.1
,,1,2022-11-28T07:26:31.098514791Z,2022-12-05T07:26:31.098514791Z,2022-12-02T07:30:00Z,5366751.612903226,ubnt-er8-LAN-out,snmp,snmp-agent,192.168.100.1
,,1,2022-11-28T07:26:31.098514791Z,2022-12-05T07:26:31.098514791Z,2022-12-02T08:00:00Z,20445214.05,ubnt-er8-LAN-out,snmp,snmp-agent,192.168.100.1
,,1,2022-11-28T07:26:31.098514791Z,2022-12-05T07:26:31.098514791Z,2022-12-02T08:30:00Z,2590409080.483333,ubnt-er8-LAN-out,snmp,snmp-agent,192.168.100.1
,,1,2022-11-28T07:26:31.098514791Z,2022-12-05T07:26:31.098514791Z,2022-12-02T09:00:00Z,3663256428.6055555,ubnt-er8-LAN-out,snmp,snmp-agent,192.168.100.1
,,1,2022-11-28T07:26:31.098514791Z,2022-12-05T07:26:31.098514791Z,2022-12-02T09:30:00Z,3690563071.3333335,ubnt-er8-LAN-out,snmp,snmp-agent,192.168.100.1
,,1,2022-11-28T07:26:31.098514791Z,2022-12-05T07:26:31.098514791Z,2022-12-02T10:00:00Z,3716531695.361111,ubnt-er8-LAN-out,snmp,snmp-agent,192.168.100.1
,,1,2022-11-28T07:26:31.098514791Z,2022-12-05T07:26:31.098514791Z,2022-12-02T10:30:00Z,3742438591.772222,ubnt-er8-LAN-out,snmp,snmp-agent,192.168.100.1
,,1,2022-11-28T07:26:31.098514791Z,2022-12-05T07:26:31.098514791Z,2022-12-02T11:00:00Z,3761546338.45,ubnt-er8-LAN-out,snmp,snmp-agent,192.168.100.1
,,1,2022-11-28T07:26:31.098514791Z,2022-12-05T07:26:31.098514791Z,2022-12-02T11:30:00Z,3782386636.866667,ubnt-er8-LAN-out,snmp,snmp-agent,192.168.100.1
,,1,2022-11-28T07:26:31.098514791Z,2022-12-05T07:26:31.098514791Z,2022-12-02T12:00:00Z,3809251600.0111113,ubnt-er8-LAN-out,snmp,snmp-agent,192.168.100.1
,,1,2022-11-28T07:26:31.098514791Z,2022-12-05T07:26:31.098514791Z,2022-12-02T12:30:00Z,3834762518.572222,ubnt-er8-LAN-out,snmp,snmp-agent,192.168.100.1
,,1,2022-11-28T07:26:31.098514791Z,2022-12-05T07:26:31.098514791Z,2022-12-02T13:00:00Z,3851447178.383333,ubnt-er8-LAN-out,snmp,snmp-agent,192.168.100.1
,,1,2022-11-28T07:26:31.098514791Z,2022-12-05T07:26:31.098514791Z,2022-12-02T13:30:00Z,3869381722.1833334,ubnt-er8-LAN-out,snmp,snmp-agent,192.168.100.1
,,1,2022-11-28T07:26:31.098514791Z,2022-12-05T07:26:31.098514791Z,2022-12-02T14:00:00Z,3891073858.422222,ubnt-er8-LAN-out,snmp,snmp-agent,192.168.100.1
,,1,2022-11-28T07:26:31.098514791Z,2022-12-05T07:26:31.098514791Z,2022-12-02T14:30:00Z,3906547400.327778,ubnt-er8-LAN-out,snmp,snmp-agent,192.168.100.1
,,1,2022-11-28T07:26:31.098514791Z,2022-12-05T07:26:31.098514791Z,2022-12-02T15:00:00Z,3909277145.138889,ubnt-er8-LAN-out,snmp,snmp-agent,192.168.100.1
,,1,2022-11-28T07:26:31.098514791Z,2022-12-05T07:26:31.098514791Z,2022-12-02T15:30:00Z,3910688711,ubnt-er8-LAN-out,snmp,snmp-agent,192.168.100.1
,,1,2022-11-28T07:26:31.098514791Z,2022-12-05T07:26:31.098514791Z,2022-12-05T07:26:31.098514791Z,28273476.31304348,ubnt-er8-LAN-out,snmp,snmp-agent,192.168.100.1
,,2,2022-11-28T07:26:31.098514791Z,2022-12-05T07:26:31.098514791Z,2022-11-30T11:00:00Z,501386235.3960396,ubnt-er8-UPLINK-in,snmp,snmp-agent,192.168.100.1
,,2,2022-11-28T07:26:31.098514791Z,2022-12-05T07:26:31.098514791Z,2022-11-30T11:30:00Z,1424182265.4333334,ubnt-er8-UPLINK-in,snmp,snmp-agent,192.168.100.1
,,2,2022-11-28T07:26:31.098514791Z,2022-12-05T07:26:31.098514791Z,2022-11-30T12:00:00Z,1799442985,ubnt-er8-UPLINK-in,snmp,snmp-agent,192.168.100.1
,,2,2022-11-28T07:26:31.098514791Z,2022-12-05T07:26:31.098514791Z,2022-11-30T12:30:00Z,2494183468.1444445,ubnt-er8-UPLINK-in,snmp,snmp-agent,192.168.100.1
,,2,2022-11-28T07:26:31.098514791Z,2022-12-05T07:26:31.098514791Z,2022-11-30T13:00:00Z,2523658860.2055554,ubnt-er8-UPLINK-in,snmp,snmp-agent,192.168.100.1
,,2,2022-11-28T07:26:31.098514791Z,2022-12-05T07:26:31.098514791Z,2022-11-30T13:30:00Z,2524246348.5,ubnt-er8-UPLINK-in,snmp,snmp-agent,192.168.100.1
,,2,2022-11-28T07:26:31.098514791Z,2022-12-05T07:26:31.098514791Z,2022-11-30T14:00:00Z,2524899992.4055557,ubnt-er8-UPLINK-in,snmp,snmp-agent,192.168.100.1
,,2,2022-11-28T07:26:31.098514791Z,2022-12-05T07:26:31.098514791Z,2022-11-30T14:30:00Z,2525331310.9722223,ubnt-er8-UPLINK-in,snmp,snmp-agent,192.168.100.1
,,2,2022-11-28T07:26:31.098514791Z,2022-12-05T07:26:31.098514791Z,2022-11-30T15:00:00Z,2529582376.911111,ubnt-er8-UPLINK-in,snmp,snmp-agent,192.168.100.1
,,2,2022-11-28T07:26:31.098514791Z,2022-12-05T07:26:31.098514791Z,2022-11-30T15:30:00Z,2533201424.1277776,ubnt-er8-UPLINK-in,snmp,snmp-agent,192.168.100.1
,,2,2022-11-28T07:26:31.098514791Z,2022-12-05T07:26:31.098514791Z,2022-11-30T16:00:00Z,2533466672.76259,ubnt-er8-UPLINK-in,snmp,snmp-agent,192.168.100.1
,,2,2022-11-28T07:26:31.098514791Z,2022-12-05T07:26:31.098514791Z,2022-12-02T07:30:00Z,5149122.225806451,ubnt-er8-UPLINK-in,snmp,snmp-agent,192.168.100.1
,,2,2022-11-28T07:26:31.098514791Z,2022-12-05T07:26:31.098514791Z,2022-12-02T08:00:00Z,10873300.388888888,ubnt-er8-UPLINK-in,snmp,snmp-agent,192.168.100.1
,,2,2022-11-28T07:26:31.098514791Z,2022-12-05T07:26:31.098514791Z,2022-12-02T08:30:00Z,79063681.92222223,ubnt-er8-UPLINK-in,snmp,snmp-agent,192.168.100.1
,,2,2022-11-28T07:26:31.098514791Z,2022-12-05T07:26:31.098514791Z,2022-12-02T09:00:00Z,162657774.55,ubnt-er8-UPLINK-in,snmp,snmp-agent,192.168.100.1
,,2,2022-11-28T07:26:31.098514791Z,2022-12-05T07:26:31.098514791Z,2022-12-02T09:30:00Z,230995305.16111112,ubnt-er8-UPLINK-in,snmp,snmp-agent,192.168.100.1
,,2,2022-11-28T07:26:31.098514791Z,2022-12-05T07:26:31.098514791Z,2022-12-02T10:00:00Z,231725066.59444445,ubnt-er8-UPLINK-in,snmp,snmp-agent,192.168.100.1
,,2,2022-11-28T07:26:31.098514791Z,2022-12-05T07:26:31.098514791Z,2022-12-02T10:30:00Z,232297218.08333334,ubnt-er8-UPLINK-in,snmp,snmp-agent,192.168.100.1
,,2,2022-11-28T07:26:31.098514791Z,2022-12-05T07:26:31.098514791Z,2022-12-02T11:00:00Z,232831326.7,ubnt-er8-UPLINK-in,snmp,snmp-agent,192.168.100.1
,,2,2022-11-28T07:26:31.098514791Z,2022-12-05T07:26:31.098514791Z,2022-12-02T11:30:00Z,233360421.69444445,ubnt-er8-UPLINK-in,snmp,snmp-agent,192.168.100.1
,,2,2022-11-28T07:26:31.098514791Z,2022-12-05T07:26:31.098514791Z,2022-12-02T12:00:00Z,233916598.14444444,ubnt-er8-UPLINK-in,snmp,snmp-agent,192.168.100.1
,,2,2022-11-28T07:26:31.098514791Z,2022-12-05T07:26:31.098514791Z,2022-12-02T12:30:00Z,234440513.06666666,ubnt-er8-UPLINK-in,snmp,snmp-agent,192.168.100.1
,,2,2022-11-28T07:26:31.098514791Z,2022-12-05T07:26:31.098514791Z,2022-12-02T13:00:00Z,234957461.58333334,ubnt-er8-UPLINK-in,snmp,snmp-agent,192.168.100.1
,,2,2022-11-28T07:26:31.098514791Z,2022-12-05T07:26:31.098514791Z,2022-12-02T13:30:00Z,235446681.08333334,ubnt-er8-UPLINK-in,snmp,snmp-agent,192.168.100.1
,,2,2022-11-28T07:26:31.098514791Z,2022-12-05T07:26:31.098514791Z,2022-12-02T14:00:00Z,236033740.51666668,ubnt-er8-UPLINK-in,snmp,snmp-agent,192.168.100.1
,,2,2022-11-28T07:26:31.098514791Z,2022-12-05T07:26:31.098514791Z,2022-12-02T14:30:00Z,238608935.05,ubnt-er8-UPLINK-in,snmp,snmp-agent,192.168.100.1
,,2,2022-11-28T07:26:31.098514791Z,2022-12-05T07:26:31.098514791Z,2022-12-02T15:00:00Z,239137738,ubnt-er8-UPLINK-in,snmp,snmp-agent,192.168.100.1
,,2,2022-11-28T07:26:31.098514791Z,2022-12-05T07:26:31.098514791Z,2022-12-02T15:30:00Z,239411240,ubnt-er8-UPLINK-in,snmp,snmp-agent,192.168.100.1
,,2,2022-11-28T07:26:31.098514791Z,2022-12-05T07:26:31.098514791Z,2022-12-05T07:26:31.098514791Z,27583213.23478261,ubnt-er8-UPLINK-in,snmp,snmp-agent,192.168.100.1
,,3,2022-11-28T07:26:31.098514791Z,2022-12-05T07:26:31.098514791Z,2022-11-30T11:00:00Z,74093663.17821783,ubnt-er8-UPLINK-out,snmp,snmp-agent,192.168.100.1
,,3,2022-11-28T07:26:31.098514791Z,2022-12-05T07:26:31.098514791Z,2022-11-30T11:30:00Z,81279552.28333333,ubnt-er8-UPLINK-out,snmp,snmp-agent,192.168.100.1
,,3,2022-11-28T07:26:31.098514791Z,2022-12-05T07:26:31.098514791Z,2022-11-30T12:00:00Z,83929908.2,ubnt-er8-UPLINK-out,snmp,snmp-agent,192.168.100.1
,,3,2022-11-28T07:26:31.098514791Z,2022-12-05T07:26:31.098514791Z,2022-11-30T12:30:00Z,88822889.98333333,ubnt-er8-UPLINK-out,snmp,snmp-agent,192.168.100.1
,,3,2022-11-28T07:26:31.098514791Z,2022-12-05T07:26:31.098514791Z,2022-11-30T13:00:00Z,89544743.09444444,ubnt-er8-UPLINK-out,snmp,snmp-agent,192.168.100.1
,,3,2022-11-28T07:26:31.098514791Z,2022-12-05T07:26:31.098514791Z,2022-11-30T13:30:00Z,89660551.57777777,ubnt-er8-UPLINK-out,snmp,snmp-agent,192.168.100.1
,,3,2022-11-28T07:26:31.098514791Z,2022-12-05T07:26:31.098514791Z,2022-11-30T14:00:00Z,89812655.68333334,ubnt-er8-UPLINK-out,snmp,snmp-agent,192.168.100.1
,,3,2022-11-28T07:26:31.098514791Z,2022-12-05T07:26:31.098514791Z,2022-11-30T14:30:00Z,89959976.45555556,ubnt-er8-UPLINK-out,snmp,snmp-agent,192.168.100.1
,,3,2022-11-28T07:26:31.098514791Z,2022-12-05T07:26:31.098514791Z,2022-11-30T15:00:00Z,92979717.97222222,ubnt-er8-UPLINK-out,snmp,snmp-agent,192.168.100.1
,,3,2022-11-28T07:26:31.098514791Z,2022-12-05T07:26:31.098514791Z,2022-11-30T15:30:00Z,97778739.24444444,ubnt-er8-UPLINK-out,snmp,snmp-agent,192.168.100.1
,,3,2022-11-28T07:26:31.098514791Z,2022-12-05T07:26:31.098514791Z,2022-11-30T16:00:00Z,97832533.31654677,ubnt-er8-UPLINK-out,snmp,snmp-agent,192.168.100.1
,,3,2022-11-28T07:26:31.098514791Z,2022-12-05T07:26:31.098514791Z,2022-12-02T07:30:00Z,259790.70967741936,ubnt-er8-UPLINK-out,snmp,snmp-agent,192.168.100.1
,,3,2022-11-28T07:26:31.098514791Z,2022-12-05T07:26:31.098514791Z,2022-12-02T08:00:00Z,503492.3277777778,ubnt-er8-UPLINK-out,snmp,snmp-agent,192.168.100.1
,,3,2022-11-28T07:26:31.098514791Z,2022-12-05T07:26:31.098514791Z,2022-12-02T08:30:00Z,3672676.327777778,ubnt-er8-UPLINK-out,snmp,snmp-agent,192.168.100.1
,,3,2022-11-28T07:26:31.098514791Z,2022-12-05T07:26:31.098514791Z,2022-12-02T09:00:00Z,30317163.75,ubnt-er8-UPLINK-out,snmp,snmp-agent,192.168.100.1
,,3,2022-11-28T07:26:31.098514791Z,2022-12-05T07:26:31.098514791Z,2022-12-02T09:30:00Z,55062812.81111111,ubnt-er8-UPLINK-out,snmp,snmp-agent,192.168.100.1
,,3,2022-11-28T07:26:31.098514791Z,2022-12-05T07:26:31.098514791Z,2022-12-02T10:00:00Z,55226871.71666667,ubnt-er8-UPLINK-out,snmp,snmp-agent,192.168.100.1
,,3,2022-11-28T07:26:31.098514791Z,2022-12-05T07:26:31.098514791Z,2022-12-02T10:30:00Z,55387772.21666667,ubnt-er8-UPLINK-out,snmp,snmp-agent,192.168.100.1
,,3,2022-11-28T07:26:31.098514791Z,2022-12-05T07:26:31.098514791Z,2022-12-02T11:00:00Z,55527908.37777778,ubnt-er8-UPLINK-out,snmp,snmp-agent,192.168.100.1
,,3,2022-11-28T07:26:31.098514791Z,2022-12-05T07:26:31.098514791Z,2022-12-02T11:30:00Z,55672150.277777776,ubnt-er8-UPLINK-out,snmp,snmp-agent,192.168.100.1
,,3,2022-11-28T07:26:31.098514791Z,2022-12-05T07:26:31.098514791Z,2022-12-02T12:00:00Z,55819649.31666667,ubnt-er8-UPLINK-out,snmp,snmp-agent,192.168.100.1
,,3,2022-11-28T07:26:31.098514791Z,2022-12-05T07:26:31.098514791Z,2022-12-02T12:30:00Z,55972369.33888889,ubnt-er8-UPLINK-out,snmp,snmp-agent,192.168.100.1
,,3,2022-11-28T07:26:31.098514791Z,2022-12-05T07:26:31.098514791Z,2022-12-02T13:00:00Z,56108326.505555555,ubnt-er8-UPLINK-out,snmp,snmp-agent,192.168.100.1
,,3,2022-11-28T07:26:31.098514791Z,2022-12-05T07:26:31.098514791Z,2022-12-02T13:30:00Z,56260602.58888889,ubnt-er8-UPLINK-out,snmp,snmp-agent,192.168.100.1
,,3,2022-11-28T07:26:31.098514791Z,2022-12-05T07:26:31.098514791Z,2022-12-02T14:00:00Z,56495414.91111111,ubnt-er8-UPLINK-out,snmp,snmp-agent,192.168.100.1
,,3,2022-11-28T07:26:31.098514791Z,2022-12-05T07:26:31.098514791Z,2022-12-02T14:30:00Z,56710456.77222222,ubnt-er8-UPLINK-out,snmp,snmp-agent,192.168.100.1
,,3,2022-11-28T07:26:31.098514791Z,2022-12-05T07:26:31.098514791Z,2022-12-02T15:00:00Z,56906205.16111111,ubnt-er8-UPLINK-out,snmp,snmp-agent,192.168.100.1
,,3,2022-11-28T07:26:31.098514791Z,2022-12-05T07:26:31.098514791Z,2022-12-02T15:30:00Z,57021015,ubnt-er8-UPLINK-out,snmp,snmp-agent,192.168.100.1
,,3,2022-11-28T07:26:31.098514791Z,2022-12-05T07:26:31.098514791Z,2022-12-05T07:26:31.098514791Z,2768267.9913043478,ubnt-er8-UPLINK-out,snmp,snmp-agent,192.168.100.1
After some search: These vlaues are the receive / transmit counters in bytes, I think since the last restart.
