Display total bandwidth usage
    OSS v9.3.6
    Try to make a panel where which can show total monthly, daily or weekly bandwidth by a server.
    Exactly not sure where to start, I am not sure if I can active this using default “node exporter” alone or I can use “exec” plugin for telegraf to read vnstat data
[[inputs.exec]]
  commands = [
    "/usr/bin/vnstat -i eth0 -tr --short --json",
    "/usr/bin/vnstat -i tun0 -tr --short --json"
  timeout = "10s"
  name_suffix = "_vnstat"
  data_format = "json"
  json_name_key="vnstat"
  tag_keys= ["interface"]
Or can use .net plugin for telegraf:
[[inputs.net]]
  ## By default, telegraf gathers stats from any up interface (excluding loopback)
  ## Setting interfaces will tell it to gather these explicit interfaces,
  ## regardless of status. When specifying an interface, glob-style
  ## patterns are also supported.
  interfaces = ["eth0", "enp0s[0-1]", "lo"]
In the end of the day, need a dashboard where I can see daily and monthly bandwidth usage by a server.
    No
    Been trying to understand promQL, grafana explorer but looks like it need clear understanding to achieve this.
Do I really need to be wizard of promQL to achieve this or it is something I can easily do ?
