Grafana - interactive linking between tables, map-location
I have made a Dashboard in grafana. I am using mariaDB as database. Created pseudo random data to test. worldmap plugin is used as map.
DB structure: There are Three sites, each sites has Two batteries, and each Battery is consists of 8 cells.
Monitoring parameters are, (1) Temp, (2) Voltage and (3) Resistance.
What I would like to do is to click the mark on the map and open the corresponding table. Also, by selecting a cell of a table to open another panel (table with corresponding information). I mean, a little interactive type.
For example there are 3 circles in the map - two green and one red indicating three sites. Is it possible to click any of the ‘site’ and that will open a new panel with information about that site?
Also, to click any cell of the table to open a new panel (table)?
Here, I have used ‘variables’ to make pull-down menus to select, ‘Site’, then ‘Battery ID’ and ‘Cell ID’ to get the corresponding graphs (below three panels). Have read that I can make link to a column of a table to open a new tab. Is there any way to open a new panel in the same dashboard?
I have just started using grafana very recently. So do not know much tricks.
If you need further clarification please tell me. I will try to explain.
Any tips or link that has explanation/discussion on this topic would be very helpful.
Thanks.
Deba
Dear sendair,
i have a same problem.
Do you found a solution ?
Welcome @danielhenrique to the community
For the map → table interaction:
Add a Data Link to your map panel that points back to the same dashboard while passing the selected Site as a dashboard variable (var-site=...).
Use the $site variable in your MariaDB query (WHERE clause) so the table only returns data for the selected site. Clicking a map marker will reload the dashboard and all panels using $site will update automatically.
For the table → detail panel interaction:
Add a Data Link to the appropriate table column passing the selected Battery ID or Cell ID as a dashboard variable. Panels using those variables will update accordingly.
If starting fresh, use Geomap instead of Worldmap → Worldmap has been deprecated.
A similar discussion you may find helpful
