Link Geomap route layer with another timeseries dashboard
Hi people!
Let me expose my problem using the template.
    Latest Grafana version v10.4.0 and running in a Docker container.
    As an image is worth a thousand words:
What I’m trying to achieve is to link a measure, for example ping, to a specific position (given latitude and longitude) in a Geomap dashboard with route layer. As far as now, this is what I have:
I can mark the position without problems, the numbers are just the ping at that location (made by me for testing). However, what I want to try is to link the dashboard I have for pings to that Geomap dashboard, so when I hover over a point of the ping dashboard, it displays me in the Geomap dashboard where it was. This is the dashboard of pings:
    Tried with different options within Geomap panel, but no success.
  • What happened?
    I’ve just followed the documentation about Geomap in the Grafana website + the link that’s in that section → ol-ext: GPX flow style
Feel free to ask anything.
Btw, sorry for the English. Thanks in advance!
So you want an onClick() event on the time series panel to trigger a change in the geomap panel?
Yes, basically. The change could be a simple pointer on the exact location.
Couldn’t the route layer have some type of configuration option to do it?
you would have to see if time series plugin exposes an 'event bus` and then you can capture that on the mapping side.
For the mapping side to respond to click event on time series, you would need to use something like leaflet.js with dynamic text (External JavaScript and CSS | Volkov Labs)
or orchestra cities map plugin that you could maybe read the event bus click on time series
