Grafana.ini when using kubernetes
    OSS, Oracle Linux, latest version
    We have a Grafana OSS working, no problems there. However, I am beginning to learn Kubernetes to get better HA between other things. I could setup a lab, and it works, meaning it starts and I can connect to the login page. I still have to work on deduplicate alerts for example.
    However, our current installation uses a MariaDB Database to store the configurations, an external LDAP for authentication, and several other bits that need to be changed in grafana.ini.
    The question is, how do I pass configuration items or a grafana.ini file to the application?
    I have been unable to find any instruction to achieve that.
  • What happened?
    I want to start the application in a Kubernetes cluster, and it should connect to the MariaDB database get our current installation (dashboards, datasources, etc).
    Deploy Grafana on Kubernetes | Grafana documentation
thanks in advance!
Generally, Kubernetes uses config maps for app configuration. (Grafana supports also configuration via emv variables, so they can be also used)
There is official Grafana helm chart, which should simplify your Kubernetes Grafana deployment. It has already option for custom grafana.ini:
