Grafana, InfluxDB, and Regex
I’m looking to create multiple variables for my charts in Grafana. I have Nagios/CheckMK data going to InfluxDB, and some of it is case-sensitive. I’ve tried using the (?i) switch, and receive errors as such:
Templating
Template variables could not be initialized: Invalid regular expression: /(?i)pco/: Invalid group
Am I missing something in the query? I’m usually good with regex, and have verified this works on other documents/platforms.
Thank you
It works for me:
tag =~ /.*(?i)$variable.*/
Did you use proper regexp operator =~ ?
back at it, and this worked. thanks
Hello Jangaraj,
I have this problem of passing value to the next panel…
More info @ this link, can you pl. help
Thx
