Case insensitive regex in variable
Hi, I’m using a regex in a dashboard variable with a Cloud Flare data source. Grafana version 10.0.0.
I need the regex to be case insensitive but haven’t managed to get it to work using options like “/gi” or “/i“ at the end or “(?i)” before the variable. e.g.
^(.(?i)${environment}.(wss|auth).*)$
Typical variable values are: Production, production, staging, Staging
They all result in invalid regular expression template errors.
Image below. Specially i need the ${environment} variable part to be case insensitive.
Can anyone help?
Apparently Grafana is based on the Go template which is not compatible with (?i) or /i flags.
I used this format [tT][eE][sS][tT] basically it means any combination of letters, one from every [] (test, Test, TEST, TeSt, etc.)
How can I apply this to a variable?
For ex: I have a variable named $region and I want the regex to match it from a datasource without case sensitivity.
/product-${host}.*/i
i - allow ignore case
I am trying to do the same thing. Have you found a way yet?
