Grafana 10.0.0
Home Assistant Core * 2024.6.3 -
Supervisor 2024.06.0
Operating System 12.3 -
Plot a series of values from my Solar instalation in W. and have a legend’s name in each one using the Alias field -
What happened?
When I populate the Alias field , graph dissapears -
To get the graph with the Alias name bellow
Click on that “Alias” string on the graph - you can see that description color for that timeseries is faded = that timeserie is not selected (probably because you clicked before on the name which you used before, so Grafana remembers that old name as selected timeseries).
Thank you very much for your quick support. Problem solved.
