Grafana in High Availability Cluster
Hello! I am experimenting with setting up a High Availability Cluster with Grafana.
Currently, I have 2 nodes in 2 Availability Zones sharing a common NFS. Grafana’s data directory (where sqlite3 file stored) is mapped to the NFS so that it is accessible from any node.
My question: is it possible (or is it safe) if I have 2 Grafana instances simultaneously sharing the same data directory with grafana.db in it? Or do I actually need to switch to MySQL or Postgres?
Hi, I am working on setting up the High Availability Cluster with Grafana. Could you please provide documentation if you have any.
Thanks.
http://docs.grafana.org/tutorials/ha_setup/
I did it.
I set up 2 server for HA, I install MySQL.
You can’t use grafana.db to share.
First, you need to do is to setup MySQL or Postgres on another server and configure Grafana to use that database.
Follow: http://docs.grafana.org/tutorials/ha_setup/#configure-multiple-servers-to-use-the-same-database
Thank you, this is useful to know, that just sharing grafana.db will not work.
