I’m running Grafana v10.4.2 on Raspberry Pi OS (Debian bookworm)
- What are you trying to achieve?
I’m trying to view my Grafana dashboard like a regular day.
- What happened?
Seeing this:
This is just the first fold, but I don’t see data on every panel.
This is happening for every machine I have, including the host on which grafana is running. So probably not machine specific.
I have visited the node exporter /metrics path manually just to make sure everything is correct. I have also been to the prometheus UI just to make sure every host is reachable.
I’m pretty sure this has something to do with Grafana self.
One weird thing. When I switch to 24 hours view, most, if not all panel gets populated.
