Dashboard is not getting any data
Hello all,
I just installed Grafana and I am not seeing any data in my dashboard.
@lonesoac0 Can you provide some more information about the version of Grafana you’re running along with data source behind those panels? I think you’re using Prometheus (what version?) and Node exporter with this dashboard template:
https://grafana.com/grafana/dashboards/1860
On the Prometheus side are you able to see in the targets section if anything is being scraped? Here’s a guide on how to see if Node exporter is scraping the system metrics: https://www.leaseweb.com/labs/2020/03/measuring-and-monitoring-with-prometheus-and-alertmanager/
First, thank you @anon80964540 for the response. I will get information as soon as I can.
