What Grafana version and what operating system are you using? I am trying to use play.grafana.
What are you trying to achieve? I wanted to test a grafana dashboard - node exporter full with auto populated data already existing.
How are you trying to achieve it? As a guest I navigated to grafana and opened the node exporter full dashboard - Grafana
What happened? I can see the dashboard loading but all the panels are rendering N/A or No data.
What did you expect to happen? I expected data to load. I tried different time ranges, and changed data source as well - but no data populated for any time period or frequency chosen.
Can you copy/paste the configuration(s) that you are having problems with? NA, url shared.
Did you receive any errors in the Grafana UI or in related logs? If so, please tell us exactly what they were. In the UI - both job and host was showing error alert so as the panels - The datasource NfggWZLGz not found.
Did you follow any online instructions? If so, what is the URL? I tried searching community forums and could not find anything related to same.
