Grafana dropdown tiles not Showing on Dashboard
  • Grafana v8.1.3 (a61f38238c)
    Creating a dashboard by sourcing the data from Graphite. The data is being fed into Graphite by using lighthouse reports which I want to be shown into Grafana dashboard
    Sending the data to Graphite using below command and I am able to integrate this with my Grafana and also can see the data in the dashboard
lighthouse-graphite https://www.mywebsite.com/help --run=3 --graphite-host=mygraphitehost --graphite-prefix=lighthouse.mywebsite_com
  • What happened?
    I can see the data being generated into Grafana but the dropdown panels are not visible. I have 3 different websites with multiple pages and I want to show all of them in Grafana. User should be able to select the domain/url/page from the dropdown and accordingly data should populate
Have you created variables for your dashboard?
Once you have created the variables, they then have to be used in the queries. You can see some example dashboards for graphite on the play site:
https://play.grafana.org/d/cvDFGseGz/graphite-templated-nested?orgId=1
This is the app variable - the edit mode in the dashboard settings:
And this is the variable being used in a Graphite query - the $app variable is substituted for the value from the dropdown when the query is executed:
