Hello new to Grafana! I was wondering if it is possible to switch between dashboards using a dropdown menu, it is for my database in postgresql
i hope it will be helpfull for you. Or can you also share your data with me? I can help you better that way.
Create a Variable for Dashboard
- Open your ‘Grafana dashboard’.
- Click the gear icon ‘Dashboard Settings’ Go to “Variables”.
- Click “Add variable”.
Add a new Panel .
Click “Field → Links” or go to Panel settings → Overrides → Add link
Add a ‘dashboard link’:
https://stackoverflow.com/questions/67263623/how-to-add-a-dropdown-menu-in-grafana
