When displaying the time series chart in dashboard panel, the lines are there but hidden with the turquoise color. The turquoise filling is only when there is data. The data is coming from Prometheus. I have already checked the fill opaque and gradient colors and all are set correctly. The time series chart in Drilldown is working fine but the same one once added to dashboard it is showing with the overlapping solid color. Image attached for reference.
Grafana version 11.6 and Windows 11 OS. -
Want to monitor our .Net application. -
Through Prometheus data collection and Grafana visual UI. -
What happened?
The time series panel not displaying the lines properly. -
The lines should be visible properly. -
“id”: 2,
“type”: “timeseries”,
“title”: “Total Requests”,
“gridPos”: {
“x”: 12,
“y”: 8,
“h”: 8,
“w”: 12
“fieldConfig”: {
“defaults”: {
“custom”: {
“drawStyle”: “line”,
“lineInterpolation”: “linear”,
“barAlignment”: 0,
“barWidthFactor”: 0.6,
“lineWidth”: 1,
“fillOpacity”: 0,
“gradientMode”: “none”,
“spanNulls”: false,
“insertNulls”: false,
“showPoints”: “auto”,
“pointSize”: 5,
“stacking”: {
“mode”: “none”,
“group”: “A”
“axisPlacement”: “right”,
“axisLabel”: “”,
“axisColorMode”: “series”,
“axisBorderShow”: true,
“scaleDistribution”: {
“type”: “linear”
“axisCenteredZero”: false,
“hideFrom”: {
“tooltip”: false,
“viz”: false,
“legend”: false
“thresholdsStyle”: {
“mode”: “off”
“axisSoftMin”: -1,
“lineStyle”: {
“fill”: “solid”
“color”: {
“mode”: “palette-classic”
“mappings”: ,
“thresholds”: {
“mode”: “absolute”,
“steps”: [
“color”: “green”,
“value”: null
“color”: “red”,
“value”: 80
“overrides”:
“pluginVersion”: “11.6.0”,
“targets”: [
“datasource”: {
“type”: “prometheus”,
“uid”: “dehp774h2ve9sb”
“disableTextWrap”: false,
“editorMode”: “builder”,
“expr”: “http_requests_received_total”,
“fullMetaSearch”: false,
“includeNullMetadata”: true,
“legendFormat”: “__auto”,
“range”: true,
“refId”: “A”,
“useBackend”: false
“datasource”: {
“expr”: “”,
“hide”: false,
“instant”: false,
“range”: true,
“refId”: “B”
“datasource”: {
“options”: {
“tooltip”: {
“mode”: “single”,
“sort”: “none”,
“hideZeros”: false
“legend”: {
“showLegend”: true,
“displayMode”: “list”,
“placement”: “bottom”,
“calcs”:
No
