"Lines:False" Override Option missing
On Grafana 7.3 in the overrides section i have an option to do “Lines:False”
On Grafana 11.2 I don’t seem to have this option.
I use this to create graphs like in example. Is this option hidden n 11.2 or its been removed?
you can crrate the same effect with Line width = 0
Thanks yeah - I already have that but I’m getting this solid light yellow from somewhere and can’t get rid of it
DO I need to do an extra overide 3 setting for the snmp.mean i wonder and that seems to be what is creating the extra
set the general -graph styles - fill opacity to 0
otherwise you have to try out a few changes
There it is!!!
Nice one. Missed that completely
