I have create a custom variable called Env with key and pair for example
Prod : wd_env_physical =“prod” Then in the markdown, when I use it like ### ${Env} metrics by Data Center. It shows the value(wd_env_physical =“prod”) not the key “Prod”. Anyone can help will be very appreciated.
Hi @jasonsong,
Welcome to the community support forums !!
We are excited that you joined our OSS community. Please read about some of the FAQs in the community
Are you trying to use the variable in the Panel Title or some place else (maybe share a screenshot for more clarity)?
Thanks
