Grafana dashboard help
Hello, I’m trying to make a dashboard that shows me my cpu usage, ram usage and hard disk space, I’m totally new to Grafana, so any help would be appreciated
Which database do you use to store your KPI ? Influxdb ?
Regards,
Hi
I’m using prometheus
regards
Here is a example : Prometheus system | Grafana Labs
Regards
Or this: Grafana
I’ll let u know if they work. As I’m a newbie to bothe Prometheus and grafana, I only used a how to guide on how to set them both up
This works but I wish there was a Hard Drive space indicator as well
Google search is your friend. Maybe this?
