Hello community,
Is there a way to display the currency to the right of the number with Grafana v11.1.0 in a table and gauge format?
Hello community,
what would it look like ?
637€K or 637K€ or 637K €
like this 637,24K €
that looks very strange value
637,24K €
Sorry, I meant either 637.24 € or 637K €
what is your data source? mysql, mssql?
what is the raw value of this number in your database or db
Yes,mssql ,It works correctly with SQL, but in Grafana, it’s not working.
With which unit did you test it, please?
select
FORMAT(SUM(MCA.montant) , ‘C’, ‘fr-fr’)
FROM ChiffreA MCA
The unit is Locale format
