Hi there i got s big local csv which i want to import
when i using the test csv everything works fine
when i try to upload my custom (~ 1 GB) csv browser crashes
log data:
logger=context userId=1 orgId=1 uname=admin t=2023-03-30T11:56:13.5056369+02:00 level=info msg="Request Completed" method=GET path=/login status=302 remote_addr=[::1] time_ms=134 duration=134.2987ms size=48 referer= handler=/login
logger=context userId=1 orgId=1 uname=admin t=2023-03-30T11:56:14.1494623+02:00 level=info msg="Request Completed" method=GET path=/api/live/ws status=-1 remote_addr=[::1] time_ms=32 duration=32.2758ms size=0 referer= handler=/api/live/ws
logger=context userId=1 orgId=1 uname=admin t=2023-03-30T11:56:17.0220805+02:00 level=error msg="Internal server error" error="[plugin.downstreamError] failed to query data: Failed to query data: rpc error: code = Canceled desc = context canceled" remote_addr=[::1] traceID=
logger=context userId=1 orgId=1 uname=admin t=2023-03-30T11:56:17.0225838+02:00 level=error msg="Request Completed" method=POST path=/api/ds/query status=500 remote_addr=[::1] time_ms=82 duration=82.0946ms size=122 referer="http://grafana.staged-by-discourse.com/explore?left=%7B%22datasource%22%3A%22XE-RAXfVz%22%2C%22queries%22%3A%5B%7B%22refId%22%3A%22A%22%2C%22datasource%22%3A%7B%22type%22%3A%22marcusolsson-csv-datasource%22%2C%22uid%22%3A%22XE-RAXfVz%22%7D%2C%22delimiter%22%3A%22%2C%22%2C%22decimalSeparator%22%3A%22.%22%2C%22header%22%3Atrue%2C%22ignoreUnknown%22%3Afalse%2C%22skipRows%22%3A0%2C%22schema%22%3A%5B%7B%22name%22%3A%22%22%2C%22type%22%3A%22string%22%7D%5D%7D%5D%2C%22range%22%3A%7B%22from%22%3A%22now-1h%22%2C%22to%22%3A%22now%22%7D%7D&orgId=1" handler=/api/ds/query
logger=context userId=1 orgId=1 uname=admin t=2023-03-30T11:56:35.6550278+02:00 level=error msg="Error writing to response" err="write tcp [::1]:3000->[::1]:56483: wsasend: An established connection was aborted by the software in your host machine."
grafana server on local win, data on same system local mode allowed via plugin
