Grafana Crash after Postgres Upgrade
  • I am using Grafana 10 deployed via Helm charts on K8. I have Postgres as DB backend for my configuration.
  • Upgrade Postgres(RDS) from 14.x to 15.x
  • What happened?
  • After upgrading Postgres to 15 Grafana is unable to connect to the Database with the following error:
    " msg=“alert migration failure: could not get migration log” error=“failed to check table existence: pq: no pg_hba.conf entry for host
    Is this a known problem?
the issue is most ptobably on the database side and not grafana
see this
