Alert migration failure: could not get migration log error=failed to check table existence: pq: role \"test\" does not exist
grafana/grafana:latest
Installing Grafana with Postgres as a database backend (not sqlite or mysql)
docker-compose.yml:
  postgres:
    image: postgres:latest # tried :14 and :13
    hostname: postgres
    restart: unless-stopped
    environment:
      - POSTGRES_DB
      - POSTGRES_USER
      - POSTGRES_PASSWORD
    volumes:
      - postgres:/var/lib/postgresql/data
  grafana:
    image: grafana/grafana-enterprise
    hostname: grafana
    security_opt:
      - no-new-privileges:true
    user: 1000
    environment:
      - TZ
      - GF_INSTALL_PLUGINS
      - GF_SECURITY_DISABLE_INITIAL_ADMIN_CREATION
      - GF_DATABASE_TYPE
      - GF_DATABASE_HOST
      - GF_DATABASE_NAME
      - GF_DATABASE_USER
      - GF_DATABASE_PASSWORD
      - GF_DATABASE_SSL_MODE
    depends_on:
      - postgres
    volumes:
      - grafana:/var/lib/grafana
    labels:
      traefik.enable: true
    networks:
      default:
      traefik:
  • What happened?
Grafana does not populate the database:
logger=migrator t=2023-07-04T12:11:36.382013641+02:00 level=error msg="alert migration failure: could not get migration log" error="failed to check table existence: pq: role \"test\" does not exist"
I can successfully connet to the database:
docker compose exec postgres psql -h localhost -U grafana grafana
Grafana should populate the database with its database scheme.
See above
Do not reach the UI. Successfully tested with default sqlite database.
Deep research without any luck. Not much findings about Grafana and Postgres in Docker environment.
We have some applications running with Docker an Postgres without any problems.
