Why Grafana running on Docker is trying to talk to
raw.githubusercontent.com (185.199.110.133)
You should to provide reproducible example. There is many options:
I’m also seeing unexpected traffic from grafana-server to 185.199.110.133
Are there other settings that I should be inspecting? Thanks.
Hi Marc,
This address also belongs to GitHub.
$ host 185.199.110.133
133.110.199.185.in-addr.arpa domain name pointer cdn-185-199-110-133.github.com.
With kind regards,
Andreas.
Thanks, Andreas, and agreed.
My question is why is grafana-server connecting to GitHub?
I have no plugins, have not configured github/gitlabs authentication, and am using a data source on the same machine on which grafana-server is running. It’s concerning from a security perspective.
I looked at the traffic using Wireshark. It’s HTTPS, so I didn’t learn much from the packet trace.
Best, Marc
Hi Marc.
This might be a silly suggestion, but let us reassure ourselves about it. You did turn off the corresponding settings in the “Analytics” section of the configuration, right?
May I also ask some more questions:
Indeed, maybe something from this subsystem will access GitHub? The new dynamic plugin catalog is on by default since Grafana 8.2, see Grafana 8.2 released: Dynamic plugin catalog, new fine-grained access control permissions, and more | Grafana Labs.
You can try to investigate by toggling plugin_admin_enabled = false.
Other than that, I would like to second @jangaraj here: Providing a reproducible example, e.g. by sharing your Dockerfile and/or corresponding command line invocations will be tremendously helpful.
With kind regards,
Andreas.
Hi Andreas,
Not silly at all … in fact both check_for_updates and reporting_enabled were enabled! I’ve disabled them and will see whether that eliminates the traffic. I’ll report back and share the invocation if it doesn’t.
I’m running 7.3.2, which doesn’t appear to have the plugin_admin_enabled option.
Also, while the original poster was running Grafana in Docker, I am not. I’m running it directly on the Ubuntu host.
With gratitude for the assistance, Marc
Dear Marc,
A quick check of the code base reveals the spot where the update checker connects to raw.githubusercontent.com:
$ ag --go githubusercontent
pkg/services/updatechecker/grafana_update_checker.go
70: resp, err := httpClient.Get("https://raw.githubusercontent.com/grafana/grafana/main/latest.json")
$ http https://raw.githubusercontent.com/grafana/grafana/main/latest.json
"stable": "8.3.3",
"testing": "8.3.3"
It might have checked at a different endpoint before, the inline documentation said https://grafana.net in previous releases and says https://grafana.com now. From the observations above, the documentation might need an update.
After disabling reporting_enabled, I believe that will be fine now.
With kind regards,
Andreas.
Hi Andreas,
After 36 hours of running with check_for_updates and reporting_enabled both disabled, I have not seen any traffic from grafana-server to GitHub.
7.3.2 apparently uses the same endpoint to check for updates as 8.3.3. A strings on the grafana-server executable returns the following.
https://raw.githubusercontent.com/grafana/grafana/master/latest.json
Thank you for your research and for pointing me to the solution … much appreciated!
This solve my issue as well. Running grafana in kubernetes so adding this to deployment file solved from trying to connect to raw.githubusercontent.com
containers:
