I am using Grafana cloud. My project in using github with codespace and the self hosted agent is in codespace. Using azure devops pipleline. -
I am trying to monitor github to get the data of pull, push, commit. -
I did data source connection using secret password and used github dashboard from the web.
I also added github api. -
What happened?
The data does not show the data.
the data is able to show. -
I didnt do any configuration on my yaml file. -
no. -
No.
