haoc
1
Hi
How to configure web login without using password.I find this configure item in grafana.ini but it can’t solve problem.
haoc
2
This solution can’t solve problem too.
Login requires a password when I use the following solution.
$ sudo sqlite3 /var/lib/grafana/grafana.db
sqlite> update user set password = NULL, salt = ‘F3FAxVm33R’ where login = ‘admin’;
torkel
3
There is a section in the ini file to enable anonymous auth.
