This product is difficult and it does not seem to work at all. I installed it and admin/admin does not work, then I uninstalled it and tried on a new Centos 7 VM and the same thing occurs. the URL coes up ok but I can not log in. http://172.18.35.54:3000/login
I am deciding the Enterprise tool for dashboards and monitoring so I hope someone can help.
This command worked:
sudo grafana-cli admin reset-admin-password admin
Anything in you grafana log ?
You can try to reset you admin password with the link below if you use sqlite database.
$ sudo sqlite3 /var/lib/grafana/grafana.db
sqlite> update user set password = '59acf18b94d7eb0694c61e60ce44c110c7a683ac6a8f09580d626f90f4a242000746579358d77dd9e570e83fa24faa88a8a6', salt = 'F3FAxVm33R' where login = 'admin';
sqlite> .exit
The command above update admin account with admin password.
Regards,
Grafana store by default user, dashboard, permission etc … in SQLite database.
And what about your log ?
About grafana configuration show me in the server section protocol , http_addr , http_port , domain
@meruem
Did you noticed I’m not the original poster ?
But I tried your command and …
pi@raspberrypi:~ $ sudo sqlite3 /var/lib/grafana/grafana.db
sudo: sqlite3: command not found
Sorry for disturbing the original poster’s thread, but it might also help anyway.
@hary66
No problem
In grafana.ini
[database]
type = sqlite3
That your configuration ?
Other think you can see is your port state
[root@localhost ~]# netstat -paunt | grep grafana
tcp6 0 0 :::3000 :::* LISTEN 1559/grafana-server
And what iptables -L command return ?
;type = sqlite3
;host = 127.0.0.1:3306
;name = grafana
;user = root
pi@raspberrypi:~ sudo netstat -paunt | grep grafana
tcp6 0 0 :::3000 :::* LISTEN 1239/grafana-server
pi@raspberrypi:~ iptables -L
iptables: Permission denied (you must be root).
pi@raspberrypi:~ $ sudo iptables -L
Chain INPUT (policy ACCEPT)
target prot opt source destination
Chain FORWARD (policy ACCEPT)
Chain OUTPUT (policy ACCEPT)
Sorry for the awful writting, i don’t know how to make it nicer.
@hary66
Every thinks seem to be OK
Try this command
If it’s still not working use tail -f /var/log/grafana/grafana.log then try to connect and see your log
use this command
cd /usr/share/grafana && /usr/sbin/grafana-server --config=/etc/grafana/grafana.ini
and try to reset your password with the previous command
Thanks! This worked great. I greatly appreciate it.
It doesn’t seem to work for me !
Should the new login/password be admin/admin ?
One point I can’t understand is how can my machine manage SQLite database if it hasn’t an SQLite server running ?
Otherwise, I found this
When installing grafana, SQLite database is automatically installed. It’s the default database for store anything about grafana (user, dasboard, permission).
I think your grafana installation is broken. Try to uninstall and install grafana. Do not forget delete /var/lib/grafana folder.
And yes login/password is admin/admin.
then restart grafana server
Admin is the username admin is the password. use capital A in username
